I am trying to build a circuit using 4060BP that would generate a 2Hz clock using a 32.768kHz crystal oscillator and then generate a 1Hz clock using 4013BP. However, when I run the circuit the LED does not turn on/off at 2Hz and 1Hz speed and when I check the frequency using an oscilloscope, I measured kilohertz of frequency. I was wondering if someone could help me figure out what is wrong with the circuit. The circuit is attached below.
