From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Multisim and Ultiboard
SPICE model DSUB CJO parameter%3F
I want to simulate this component which has a particularly low gate threshold so I want the model to be the right one.
This comes from Diodes Inc DMN5L06DWK.
MS seems to have problems with the .model DSUB CJO parameter and claims it results in a negative value.
I just deleted the CJO parameter and it works.  I haven't been able to find a reference to help me understand this syntax.
Here is the model as provided and with the problem line commented and fixed to run.
Can anyone explain what the deal is with the DSUB model and the CJO parameter?
Thanks.
*---------- DMN5L06DWK Spice Model ----------
.SUBCKT DMN5L06DWK 10 20 30
*     TERMINALS:  D  G  S
M1 1 2 3 3 NMOS L = 1E-006 W = 1E-006
RD 10 1 1.449
RS 30 3 0.001
RG 20 2 127
DESD1 2 5 DESD
DESD2 3 5 DESD
CGS 2 3 2.688E-011
EGD 12 0 2 1 1
VFB 14 0 0
FFB 2 1 VFB 1
CGD 13 14 5E-011
R1 13 0 1
D1 12 13 DLIM
DDG 15 14 DCGD
R2 12 15 1
D2 15 0 DLIM
DSD 3 10 DSUB
.MODEL NMOS NMOS LEVEL = 3 VMAX = 8E+005 ETA = 0.0001583 VTO = 1.189 TOX = 6E-008 NSUB = 1E+016 KP = 1.163 U0 = 400 KAPPA = 14.08
.MODEL DCGD D CJO = 1.808E-011 VJ = 0.134 M = 0.369
.MODEL DSUB D IS = 247.6E-9 N = 1.566 RS = 0.358 EG = 0.06341 XTI = 8.194
+ TNOM = 217.5 BV = 70 VJ = 1.307E-009 M = 0.03355
*+ TNOM = 217.5 BV = 70 CJO = 2.877E-012 VJ = 1.307E-009 M = 0.03355                    -------delete CJO for this to work in MS?
.MODEL DLIM D IS = 0.0001
.MODEL DESD D IS = 2.728E-008 N = 66.22 BV = 5.068
.ENDs
*Diodes DMN5L06DWK Spice Model v1.0 Last Revised 2013/2/18
(4,035 Views)
Are you getting a particular error, or are you seeing incorrect simulation results? I was able to run a simulation with this model and no errors, so I'm not sure what the problem is.
Could you attach your circuit or netlist, or maybe just a screenshot of the errors or incorrect results?
Jeff
(3,978 Views)
Yes you were able to simulate that listing because I already commented out the problem line.  Restore that commented line and see the error you get trying to simulate. (comment out the 'fixed' line)
(3,971 Views)
