Multisim and Ultiboard
How to convert or export/import pspice .asc format into multisim
I have a simple circuits which had implemented in PSPICE .asc format, those i want to use in NI Multisim, what is the procedure to do that.
(11,842 Views)
Hi there,
Is your pspice.asc format file created by LTSpice? Actually, you can create this simple circuit using Multisim. The following is a tutorial for tansitioning from PSPICE to Multisim. Hope it helps!
Transitioning from PSPICE to NI Multisim: A Tutorial
http://www.ni.com/white-paper/5964/en/
Chen_T
(11,828 Views)
Thanks for your response.
those files are created in LTspice .asc format, we have around more than 200 files which we dont have time to spend for re-implementing in the Multisim, So just i want to know is there any option to get those files in multisim.
Vikram Kumar P
(11,812 Views)
Hi Vikram,
I understand that it is time consuming to re-implement these files, but so far we really do not have this feature in Multisim. Maybe in the near future, we will include this conversion function.
Chen_T
(11,794 Views)
Is still the same issue until now?
Because I would like to import some files from LTspice to Multisim
(5,557 Views)
Hello, I have a Pspice schematic for the ucc28070 chip, it opened in my multisim but it doesn't work. Can you tell me how to activate it? Thank you for your attention
How to convert or export/import pspice .asc format to multisim
(986 Views)
