Multisim and Ultiboard
Analyzing Quiescent Currents and Voltages of H-Bias Common Emitter Amplifier
I am trying to analyze the DC Quiescent values for a 2N3904 Transistor. I determined the resistor values I will need to have to work with a 20V supply and a quiescent collector current of 2.5 mA. My question is how do i simulate this transistor in multisim online the default npn does not seem to give the expected values. I have the spec sheet for the transistor and it has spice data but i am unsure how to use this.
https://www.multisim.com/content/wG7r9EyWbgNqEoruCmpYVg/dc-analysis-h-bias-amplifier
(3,082 Views)
Accepted by Jaydaar
Hi Jay!
from my understanding, this is a generic npn transistor. If you have the SPICE model of the 2N3904, you can compare and edit it with the one on Multisim Live. I have attached a screenshot on where you can check this.
Once you found it, you can edit it and run your tests.
Have a great day!
(3,057 Views)
I realized my version is trial so I cannot change the model. thank you
(3,048 Views)
