10-23-2013 09:24 AM
How do you determine the accuracy of an analog out waveform on the PXI6230?? I can't use the counter timer output.
My reqmnt is +/- 0.1 msec. I'm guessing that means for 1 KHZ waveform ( 1 msec) My waveform generated can be 909.09 to 1111.11 KHz and still be in spec. How do I use the cards spec to figure if its accurate enough?
The card has an update rate of 500ks/sec or 1 sample every 2 microsec. So my update rate is 3 mags better than my reqmnt of 1 msec. Is that a valid argument?? Why or why not?
thxs..
10-23-2013 11:25 AM
In the Specification Sheet for the PXI 6320 it list AO Specs as:
