06-22-2006 05:46 AM
06-22-2006 08:54 AM
With 7.1, hardware drivers are not part of the installer you create when you build the LabVIEW exe. You can manually add the DAQmx installer to the build or separately provide the DAQmx installation that came with the device.
DAQmx Base has been replaced with the full DAQmx version on windows platforms. DAQmx contains quite a few more features but I'm not sure if all of the additional features apply to the 6009. The base functions are usually a simple replace I believe. For example, replace DAQmx Read base with DAQmx Read.
06-22-2006 11:53 AM
Hi Johnie-
I'd like to expand on Dennis' suggestion to use NI-DAQmx rather than NI-DAQmx Base. This utility will automatically update any existing VIs from NI-DAQmx Base to NI-DAQmx, and you will enjoy other NI-DAQmx features such as multi-threading, troubleshooting in Measurement and Automation Explorer (MAX), the DAQ Assistant, and many more.
06-22-2006 12:13 PM
Thank you for advice.
I did as you had suggested, downloaded latest version Daqmx and other softweare that should made my programs' conversion possible but unfortunately when I attempt to launch new version MAX or Base2MX convert. vi I recive a message: " Executable version (7.1.1) doesn't match resource file (7.1). Check your configuration."
I have no idea what can cause this problem that make suggested solutions unpossible. This same message I recive when trying start build .exe application.
Does anyone have any idea what's going on?
Many regards,
Johnnie
06-22-2006 01:24 PM
