09-13-2009 04:17 AM
09-14-2009 04:10 PM
Try changing the sampling rate make it higher. i.e. if the signal is 500 Hz try smapling rate of 5KHz with samples to read about 1000. Also check your on the scope to make sure it is clean signal coming out of your sound card.
-Cheers
lab
