You may take a look at the following link for a list of SCXI products.
SCXI PageSCXI-1520 SCXI-1540 The first link contains information about the list of SCXI products.
The second and third links contain information about SCXI-1540 and SCXI-1520 that are used with LVDT and strain gauge sensors respectively.
Because of the inherent differences in the way measurement is done with an LVDT sensor and a strain gauge sensor, the modules that they can be used with are different.
Pressure sensor and load cell both can be used with a strain gauge modu
le such as SCXI-1520.
But SCXI-1520 cannot be used with LVDT and in order to use LVDT, you need SCXI-1540.
Sincerely,
Sastry V.
Applications Engineer
NI
