Fabrizio,
I think we need to know more about the application you are willing to implement.
As noted in this document about
CF-6004 Sampling Rates, the maximum rate achievable strongly depends on the type of acquisition your are looking for.
Also, by looking at the
CF-6004 User Manual you can see that there is no possibility for an external clocking source.
As far as PDAs are concerned, the specifications you should be looking for are related to the Operating System running on the PDA.
LabVIEW PDA Supports Windows Pocket PC 2003 (Mobile 2003 PocketPC) and Windows CE.NET 4.2, provided this has been built using the Standard SDK Package as shown in this
KnowledgeBaseThis is a
FAQ on CF-6004The other key parameter is the Processor on which the device is based. It must be an ARM based processor.
As far as the mux goes, chances are you would need to implement a way to control the external mux and on top of this, you also need to verify that the 20 KHz Sampling rate is achievable.
AlessioD
NI
