Multifunction DAQ
ni9265
Is there an analog output and input  module that I could use to program 4-20 ma under control of Signal Express. I would like to drive a device for 3 seconds at 12ma and three seconds at 20ma. I would also like to take an analog sample during each state. If I purchase the right hardware, can SE do this without having to do any programming in LV.
thank you,
john
(2,712 Views)
Yes you can do this in Signal Express.  If you get stuck on this please post back and we can help.
To get 4-20mA current output you will need one of these:
4110 For PXI and a lot of current output http://sine.ni.com/nips/cds/view/p/lang/en/nid/202609
4130 PXI http://sine.ni.com/nips/cds/view/p/lang/en/nid/204239
6704 PCI or PXI http://sine.ni.com/nips/cds/view/p/lang/en/nid/10705
9265 cDAQ http://sine.ni.com/nips/cds/view/p/lang/en/nid/201848
None of these can do analog input, but there are TONS of choices depending on what you need for that.  Would you just be taking one sample?  If not what rate?
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
(2,696 Views)
