03-16-2009 07:47 PM
I have an application using PCI-6111 and PCIe-1427 frame grabber made in vc++ 6.0. But I have an error saying "This application has failed to start because MSVCR80.dll was not found. Re-installing the application may fix this problem." I have a respose from microsoft as shown in the URL below. It seems that NICAIU.DLL and IMAQ.DLL are to be upgraded using vs 2005.
I have the most updated NI-Vision 8.5.1 and NIDAQmx 8.9 and MAX 4.5.
03-18-2009 12:08 AM
I would try shifting the DLL to another folder and then making sure that you are referring to this file path correctly within your VC++application.I would also try calling this DLL from within a newly created application.
04-07-2010 01:45 PM
Hello-
I am seeing this same error running on 64-bit windows 7. When I build the project on my xp system, everything is fine.
Any advice?
-Bill
04-07-2010 07:41 PM
Hi there,
I encountered the same problem when using Windows 7. It seems that this has to do with the file system of windows 7 using winsxs. If you have deleted some files (files with very long names that are generated by Windows 7), this error would pop up. When I tried to copy the whole project to another harddrive and rebuild again, it works! You may want to try this, see if it works!
