09-18-2009 10:29 AM
When I connect chassis cDAQ-9172 with module 9215 & 3 other modules to the computer via the USB port, the computer loads the drivers for the 9172 (no applications were running). A window opens and I select "take measurements with Signal Espress". An image of the chassis appears but no modules are displayed for selection. I want to use the 9215 analog input which is installed in the chassis.
When I first open Signal Express and select Add Step then select acquire then select DAQmx then select Analog then select Voltage. After waiting a window opens an says "no supported devices found".
Yesterday I was using Singal Express with the 9215 analog input in the USB Carrier USB-9162. This indicates the program and module work.
How do I get the system to recognise modules in the chassis?
09-21-2009 06:20 PM
