int32 CVICALLBACK EveryNCallback on gcc
I am configuring a code for continuous sampling using NI-DAQmx (6255). In the ANCI C sample codes, the following is used:
int32 CVICALLBACK EveryNCallback(...
Is this only for CVI environment or can I use it on gcc too?
Cheers
(2,589 Views)
Reference here:
https://forums.ni.com/t5/Multifunction-DAQ/How-Can-I-Use-The-NI-DAQmx-ANSI-C-Function-Library-With-G...
Using NI-DAQmx in Text Based Programming Environments
http://www.ni.com/tutorial/5409/en/
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
http://www.ni.com/product-documentation/2835/en/
How Can I Use the NI-DAQmx ANSI C Function Library with Borland C and Delphi?
http://digital.ni.com/public.nsf/allkb/B09727F89DA3A06C86256F430071D88E
(2,495 Views)
Nope, I have already generated the necessary library for the gcc compiler. I just want to know whether  " int32 CVICALLBACK EveryNCallback " works on gcc. I am not sure since it calls CVICALLBACK. I was able to compile the sample code. But I dont know if it will work fine with the device.
(2,458 Views)
CVICALLBACK is just a #define to (ultimately) tell the compiler to use the __cdecl calling convention:
#if defined(__linux__) || defined(__APPLE__)
#define __CFUNC
#define __CFUNC_C
#define __CFUNCPTRVAR
#define CVICDECL
#define CVICALLBACK     CVICDECL
#else
#define __CFUNC         __stdcall
#define __CFUNC_C       __cdecl
#define __CFUNCPTRVAR   __cdecl
#define CVICDECL        __cdecl
#endif
Assuming that gcc understands the __cdecl keyword it should work fine.
(In this context "CVICALLBACK" isn't specific to CVI, it refers to any C environment. The "CVI" prefix is present for historic reasons.)
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(2,454 Views)
