error -209836
        I just installed everything without problem. Each and every NI hardwares can pass self-test. But this error -209836 popup for NI9375 and NI 9401 both when I tried to test in Test panels. Some one can help? thanks.
      My PC is with Win10 x64 pro.
(1,719 Views)
Try the steps in Error -209836 in DAQmx Start Task on TSN-Enabled cRIO or cDAQ
Control Lead | Intelline Inc
(1,708 Views)
Don't have labview developement.(Evaluation expired)
Just need hardware work for deploy a teststand project.
And reset NI-Max database didn't help.
(1,698 Views)
Which code module type you are using in TestStand?
If you don't have a license for LabVIEW, you can try text-based programming like C, C# or Python.
Using NI-DAQmx in Text Based Programming Environments
Using a NI DAQ Device with Python and NI DAQmx in Windows
(1,679 Views)
Thanks, TYong
It's labview base teststand project
And it can work on other PC with same configration.
Can update NI-DAQmx drive fix it? higer version?
But my labview code is based on 2015😵
(1,660 Views)
Accepted by topic author Matt0472
update to NI DAQmx-19.1,problem disappeare.
(1,626 Views)
