09-23-2023 05:54 AM
I just installed everything without problem. Each and every NI hardwares can pass self-test. But this error -209836 popup for NI9375 and NI 9401 both when I tried to test in Test panels. Some one can help? thanks.
My PC is with Win10 x64 pro.
Solved! Go to Solution.
09-23-2023 06:48 AM
Try the steps in Error -209836 in DAQmx Start Task on TSN-Enabled cRIO or cDAQ
09-23-2023 07:21 AM - edited 09-23-2023 07:24 AM
Don't have labview developement.(Evaluation expired)
Just need hardware work for deploy a teststand project.
And reset NI-Max database didn't help.
09-23-2023 08:18 AM
Which code module type you are using in TestStand?
If you don't have a license for LabVIEW, you can try text-based programming like C, C# or Python.
Using NI-DAQmx in Text Based Programming Environments
Using a NI DAQ Device with Python and NI DAQmx in Windows
09-23-2023 11:37 AM
Thanks, TYong
It's labview base teststand project
And it can work on other PC with same configration.
Can update NI-DAQmx drive fix it? higer version?
But my labview code is based on 2015😵
09-23-2023 08:34 PM
update to NI DAQmx-19.1,problem disappeare.
