cDaq-9174 shows empty slots
I have recently bought this cDAQ-9174 with 3 modules installed: 9211 9234 9263.
I have Last version of Labview 8.6.1 (First Quarter 2009) and NI-DAQmx 9.0.1 drivers supplied with hardware installed in my system.
When I open MAX it shows  empty slots.
How can I fix it?
Message 1 of 8
(4,459 Views)
Hello Sergey,
Could you try removing the modules from the chassis and re-adding them?  Also, once they are added, what are the three LEDs on the front of the chassis doing?  Finally, what is listed in Device Manager under Data Acquisition Devices?
undefined
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 2 of 8
(4,453 Views)
Hi Sergey,
I have found this KB which has some quite useful tips and troubleshooting steps when NI hardware is not recognised.
Best Regards,
Christian Hartshorne
Applications Engineering
Andrew McLennan
Message 3 of 8
(4,433 Views)
Apologies for that confusion, I was signed into a colleagues profile.
Hi Sergey,
Best Regards,
Message 4 of 8
(4,430 Views)
I can see devices in Device Manager.
I have even followed the guides and disconnected cDAQ and reinstalled drivers(uninstalled and installed back after reboot).
It did not help.  It still shows empty slots.
Help!!!
Message 5 of 8
(4,417 Views)
Accepted by topic author Sergey(PSU)
Hello Sergey,
I believe the issue has to do with the chassis itself.  Because this is a very inconvenient issue and is also very rare, I would like to get your chassis replaced and the defective one sent to R&D sot hat we can figure out what is wrong with it.  May I have your permission to have our Web Support Team retrieve the email address for your account so that I may contact you directly to get this issue resolved?
Seth B.
Message 6 of 8
(4,405 Views)
Yes sure you can contact me and I can get the replacement ASAP.
Message 7 of 8
(4,391 Views)
The replacement of cDAQ9174 helped immediately.
Thanks.
Message 8 of 8
(4,239 Views)
