05-14-2014 09:44 AM
I have this device with model number cDAQ-9188 and I am looking to interface to it so I can save the data to database. I was wondering if there was a SDK to interface to it via TCP/IP.
Thank you.
05-14-2014 01:52 PM
05-14-2014 03:13 PM
Hello Denise,
Thank you for your reply.
I plan to use C# to interface to this device through TCP socket programming.
05-14-2014 04:37 PM
06-19-2014 11:49 AM
Hello Dennis,
Sorry about getting your name wrong.
Thank you for your help.
I have downloaded Ni-DAQmx Kit and I notice there are a lot of examples there. I am trying to connect to thermocouples connect to this NI device called NI cDAQ-9188 with serial no 015ED821.
Can you point me to an C# example in that SDK that would be helpful?
Really appreciate the help.
Bhanu
06-20-2014 09:08 AM
Hi Bhanu0911
There are C examples that are installed with NI-DAQmx if you checked them while you were installing.
Those examples should be in this path: C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
Please let us know if you are able to find them,
