Hi Gene,
This
document is a good resource when trying to figure out the Driver version that you need to use with a card on a certain operating system. I looked up PCI-6110 (which is the newer name for the PCI-6110E as shown in this
knowledgebase) and found that you can either use NI-DAQmx 8.6 or NI-DAQ 7.4.4 (Traditional DAQ) on Windows XP. If you are starting fresh with a new application, I would recommend using DAQmx since it is an easier driver to program with. However, if you have another application in W98 where you were using Traditional DAQ, it would be easier to transfer this over if you downloaded the traditional driver.
Here is a
link to the drivers and updates page on the website where you can search for and download the driver that you need. Hopefully this information was helpful!
Vanessa L.
Applications Engineer
