05-18-2021 12:54 PM
Hello there,
I have been using NI USB-9162 compactDAQ chassis with my NI 9215 DAQ. I want to purchase a new one, and this page tells me that the product is mature and that there is an upgrade.
https://www.ni.com/en-ca/support/model.usb-9162.html
what is the upgraded version? and should I be able to use just like the matured version?
Best,
Ebrahim
05-18-2021 01:22 PM
Start going here: CompactDAQ Chassis. Use the filter to reduce the number of slots to 1 and bus of USB 2.0. You will see that pretty much your only option is cDAQ-9171.
The USB-9215 will be unorderable at the end of the year, so I would avoid going that route.
