Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
04-04-2012 02:07 PM
When an I/O on the NI USB-6501 is configured as an input, is the 4.7k pull-up to the internal 5V present on the I/O or is the pull-up only there if configured as an open-drain output?
Solved! Go to Solution.
04-04-2012 03:05 PM
That pull-up is in hardware... doesn't change when you reconfigure the port. It's just inside the output terminals.
Thanks!
We'll be in touch soon!
