Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
11-14-2013 01:06 AM
I would like to sample multiple channels using different sampling rates continuously and simultaneously. Is this possible? If yes, then how do I combine the channels measurements together in a graph?
11-14-2013 10:41 AM
No, all channels on the 6366 share a sample clock.
You could sample fast and then decimate a subset of the channels in software if the concern is too much data.
Best Regards,
Thanks!
We'll be in touch soon!
