I have a NI USB-6210 and I am recording differential analogue inputs from a geophone. I want to switch the gain settings of my data logger from +/- 10V to +/- 0.2V: which are the two extreme options according to the unit's specifications.
I cannot find a 'switch' in DAQExpress for doing this. If I alter the input voltage ranges for the channel in DAQExpress, the precision of the exported data remains the same.
Can anyone suggest a solution for this issue ?
Thank you....
