01-10-2007 10:45 AM
01-11-2007 05:40 PM
Hi Chris,
Setting the AI converte rate is not supported on the USB-600x series. You are correct in that you have control over the sample rate, that is the number of samples taken per second. From the DAQmx C Reference Help -
"By default, NI-DAQmx selects the maximum convert rate supported by the device, plus up to 10 microseconds per channel settling time. Other task settings, such as high channel counts or setting Delay, can result in a faster default convert rate. "
Hope this helps,
Andrew S.
03-16-2007 10:15 AM
03-19-2007 05:57 PM
03-19-2007 07:25 PM
03-20-2007 04:58 PM
03-22-2007 09:22 PM
03-23-2007 10:01 AM
03-23-2007 10:29 AM
03-26-2007 10:09 AM
