USB-6008 DAQ not detected in LabVIEW
So my USB-6008 DAQ device is not available when I make a new DAQmx task (or open up DAQ assistant).
I found this link: http://digital.ni.com/public.nsf/allkb/179BC9B0266168288625722100738C22
I've done all there is told but LV is still not detecting my USB-6008.
As you can see from the image below it is detected by the measurement and automation explorer. I don't know how to test it with the visa test panel though.
undefined
After this I tried to test it with the diagnostic utility, and here it doesn't show up in the list.
I've downloaded the correct drivers (multiple times) but still nothing.
Can anyone help me with this?
Message 1 of 14
(6,930 Views)
Exactly what driver did you install? It's showing as a USB RAW device and that is not correct. What is your os?
Message 2 of 14
(6,920 Views)
this one for Labview (version 8.5):
http://www.ni.com/download/ni-daqmx-8.5/276/en/
And this one for the USB-6008:
http://www.ni.com/download/ni-daqmx-base-3.3/1343/en/
I'm working on Windows 7 64-bit.
Message 3 of 14
(6,914 Views)
Installing the base version is not correct. Where did you get the idea that it was required for the 6008? You can use base but then you cannot use the DAQ Assistant or obviously any DAQmx tasks.
Message 4 of 14
(6,911 Views)
Version 8.5 is also obviously wrong since you can see it does not support Windows 7.
Message 5 of 14
(6,908 Views)
Hey Fatsat,
Can you download this driver, install it and check if everything works correctly?
http://www.ni.com/download/ni-daqmx-9.8/4297/en/
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 6 of 14
(6,892 Views)
Just downloaded and installed it.
It now comes up like this in the M&A explorer:
undefined
I think this looks ok? The problem is that now i can't find the DAQ assistant within labview. Also when I want to make a new DAQmx task, no window pops up with the configurations, ports, ...
I did reboot my computer and the files are installed correctly.
Message 7 of 14
(6,880 Views)
ThiCop gave you a link to a version of DAQmx that does not support your version of LabVIEW? Is LabVIEW 8.5 what you are using?
Message 8 of 14
(6,877 Views)
I just searched google after I noticed things weren't working the way they should.
Probably typed something like 'USB-6008 driver' and evantually came up with a page full of those 'base' versions.
Message 9 of 14
(6,875 Views)
That's actually what I thought in the first place. That's why I downloaded the one I stated a few comments back...
Message 10 of 14
(6,870 Views)
