01-03-2006 03:14 PM
01-04-2006 01:45 PM
Hi Kray-
When the I/O lines are configured for output they default to a logic high (i.e. 5V) output state. The device specifications do not include any specification about the glitch associated with the configuration change, but the glitch should be small. If you need well-regulated glitch-free startup you could also consider a more robust industrial digital I/O device.
Hopefully this helps-
