USB-6002 pressure gauge readings give strange step function
Hi all,
I have the current set-up below:
- OMEGA pressure gauge connected to signal amp connected to USB-6002, finally connected to laptop (powered by AC adaptor) via USB
- Differential mode
- I am using a MatLab program to capture the data
I am seeing this step-wise function in the Volts (V) vs Time plot (s). Any idea why this is happening? The set-up is well grounded. I have attached a sample 10 sec data at 100 Hz.
Thank you in advance for your help!
Victor
(2,027 Views)
Addendum: This quantised effect is not present in RSE mode (Volts vs time (s))
(2,016 Views)
Accepted by topic author victorkangnz
At a glance, it sure looks like A/D quantization.  Note that both the X and Y axes in your second posting have a significantly different scale than in your first.  The quantization is probably still there, it's just obscured by all the additional noise and the much wider view.
-Kevin P
Present job ending soon. Need DAQ expertise? PM with serious opportunities.
(2,000 Views)
Thank you very much, Kevin!
(1,961 Views)
