annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
The sampling rate setting in DAQmxCfgSampClkTiming
I would like to set up the sampling rate of PCI-6251with DAQmxCfgSampClkTiming(*taskHandle,"",SampRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,samplesPerChan) for multi AI channels. The 6251 manual says the highest sampling rate for signle channel is 1.25M and 1M for multi-channel. Does that mean I have to set the SampRate to be 1M or it has to be divided by the number of channels (500K if I have two analog inputs?)?
David.
0 Compliments
Message 1 sur 5
3 942 Visites
Hi David!  look  here
It seems that you have to divide!
Graziano
0 Compliments
Message 2 sur 5
3 935 Visites
Note: I refer to Ayman  post...
0 Compliments
Message 3 sur 5
3 933 Visites
Hello David,
Graziano is right, it's 1MS/s divided by the number of channels in the scan list.
Micaela
Micaela N
0 Compliments
Message 4 sur 5
3 924 Visites
Thanks guys!
0 Compliments
Message 5 sur 5
3 916 Visites
