03-18-2019 08:04 PM
Perform a VI where the signal of a variable of an industrial process (Lm35) is acquired, which gradually increases until reaching the value of 100 in a span of 20s. From here and after 10s the variable adjusts to a double value, after another 10s it doubles again and within another 10s it is reduced by half. A "Process Started" LED should light up throughout the process. You can stop the process at any time in the stop button.
03-19-2019 02:23 PM
What is the question?
I can recommend you to use a state machine on LabVIEW.
http://www.ni.com/tutorial/7595/en/
Have a nice day!
03-21-2019 01:39 PM
Have you use some LabVIEW example?
