06-25-2014 03:58 PM
I'm trying to use the analog outputs on a PXI-4461 to drive a fast steering mirror. I need to set each AO channel to some DC values, wait a short period of time for the mirror to settle, and then measure something. I can use the AO channels to output the values using this code:
void PxiMirrorAxes::set_dc(double valX, double valY) { int i; for (i=0;i<buffer_size/2;i++) // Write a bunch of the same value to a small buffer { buffer[i]=valX; buffer[i+buffer_size/2]=valY; } if (taskHandle) { // If a task is currently running stop it DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); taskHandle = 0; } int err; err= DAQmxCreateTask("",&taskHandle); err = DAQmxCreateAOVoltageChan (taskHandle, chan_char_x, "", -10.0, 10.0, DAQmx_Val_Volts , NULL); err = DAQmxCreateAOVoltageChan (taskHandle, chan_char_y, "", -10.0, 10.0, DAQmx_Val_Volts , NULL); err = DAQmxCfgSampClkTiming(taskHandle,"",sampling_rate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,buffer_size/2); int32 written; err = DAQmxWriteAnalogF64(taskHandle,buffer_size/2,0,10.0,DAQmx_Val_GroupByChannel,buffer,&written,NULL); err = DAQmxStartTask(taskHandle); // Task is left running }
This works fine to go to a specific pair of values and stay there -- however I can't call this in a loop to scan the mirror because every time I call it, the value of the outputs briefly drops to zero, presumably when I call the DAQmxStopTask. How do I change the output values of the two channels without them going to zero at all? (Note that when I use code like the above with a normal PCI-based DAQ where I don't have to write a buffer, it never goes to zero between calls). Thanks,
Alex
06-26-2014 10:24 AM - edited 06-26-2014 10:25 AM
Just to follow up, I was able to do this by calling the following code once at the start of the loop:
void PxiMirrorAxes::prep_sweep() { if (taskHandle) { // If a task is currently running stop it DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); taskHandle = 0; } int err= DAQmxCreateTask("",&taskHandle); err = DAQmxCreateAOVoltageChan (taskHandle, chan_char_x, "", -10.0, 10.0, DAQmx_Val_Volts , NULL); err = DAQmxCreateAOVoltageChan (taskHandle, chan_char_y, "", -10.0, 10.0, DAQmx_Val_Volts , NULL); err = DAQmxCfgSampClkTiming(taskHandle,"",sampling_rate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,buffer_size/2); int i; for (i=0;i<buffer_size/2;i++) { buffer[i]=0; buffer[i+buffer_size/2]=0; } int32 written; err = DAQmxWriteAnalogF64(taskHandle,buffer_size/2,0,10.0,DAQmx_Val_GroupByChannel,buffer,&written,NULL); err = DAQmxStartTask(taskHandle); i=1; }
and then calling the following every time I wanted to change the value:
void PxiMirrorAxes::sweep_set(double valX, double valY) { int i; for (i=0;i<buffer_size/2;i++) { buffer[i]=valX; buffer[i+buffer_size/2]=valY; } int32 written; int err = DAQmxWriteAnalogF64(taskHandle,buffer_size/2,0,10.0,DAQmx_Val_GroupByChannel,buffer,&written,NULL); now_x = valX; now_y=valY; }
Each subsequent DAQmxWriteAnalogF64 call returns the warning 200015: DAQmxWarningPotentialGlitchDuringWrite (discussed here), but since that describes what I want to happen anyways, I'm just ignoring it.
