From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
SCXI chassis problem
communication problem with SCXI. Replaced communication board in PC, no effect. Went back to original board. Rebooted SCXI (turn off-on). One of SCXI modules appears to be working (MD1), but others are not. MAX shows communication established after SCXI boot. Modules that are not communicating? are 1100 and 1102.
(2,628 Views)
Hello WT Carter,
When you say you are having communication trouble, does this mean that the modules are not properly being autodetected in Measurement & Automation Explorer (MAX)?  I would recommend trying to start fresh by just deleting and recreating your SCXI system in MAX.  See if the modules can be properly autodetected, and then test the signals acquired by the modules using the Test Panels in MAX.  Also, try taking a look at this post, and see if any of these suggestion help.  If this does not help, try posting back with some more detailed information about the communication problems you are experiencing, and the steps you've gone through to configure your SCXI system.
Travis G.
Applications Engineering
www.ni.com/support
(2,616 Views)
