12-23-2005 09:02 AM
12-23-2005 10:36 PM
The device pin-outs given in this manual for your PCI-6221 should match with your SCB 68 pin numbers.
As far as i know, the switch settings on SCB 68 has not changed for M series.
Plus your MAX also shows the device pinouts.
Go to device and interfaces, click on your card and select for device pinouts from the drop-down menu.
hope this helps
Regards
Dev
12-27-2005 08:55 PM
Hi All-
You can find quick reference labels for most other 68 pin cards here.
Hopefully this helps-
