Multifunction DAQ
Programming USB 6009 with Visual Studio 2010 (without Measurement Studio)
I want to control the engine speed via NI-USB 6009. The engine speed is given me as a analog voltage signal. Now I am looking for a program (in Visual Studio 2010), that continuously acquires the data via a analog input channel. With this data I want to make some calculations and the results of these calculations should be sent to the digital output of the USB 6009 in realtime.
Maybe some of you have ideas or examples.
Thank you 🙂
(5,255 Views)
No ideas? 😞
(5,196 Views)
You won't need Measurement Studio, but you will need DAQmx installed.
http://www.ni.com/example/29497/en/
Curt
(5,186 Views)
Ok, thank you
One last question:
I can´t find a example programm (using C and Visual Studio), that reads data from a analog input and writes this data to a analog output.
Such a programm maybe doesn´t make sense, but I need such one.
(5,175 Views)
(5,164 Views)
