Hi, I have encountered a problem when using the USB-9234 and would appreciate any advise.
basically, there are 4 channels on the USB9234. I created a task for each channel, Say Task A for dev1/ai0, Task B for dev1/ai1 etc..
When I started task A, and immediately followed by task B (before Task A finish acquisition), and error message appears as shown in the attached file.
My question is, can't the USB-9234 acquire signal independently? Or must Task A be completed then task B can start?
Or is it necessary to put all the channels into 1 task? In this case, the different channel must start or stop together and cannot run independently. Is this a limitation of the device?
Thak you for your kind attention.
