09-25-2018 04:31 AM
Hello everybody,
This is my first post so please forgive me if I make any mistake explaining myself. I am working in a MAC environment with LabView 2012 and with a DAQ NI USB-6218. I am trying to generate two analog signals at the same time. A first square signal and a second constant amplitude signal.
I made a code that worked as expected before but I don't know why it doesn't work anymore. I am very confused with its behavior and where is the problem. In summary, when I start the code, I have my square signal but my constant voltage signal is always placed on zero volts no matter what I do (measurements and outputs viewed by oscilloscope). Can you please give me a hand to solve this problem?.
As I said, it worked before and I didn't touch the code since then. I cannot understand what is happening.
Thank you in advance
10-22-2018 10:48 AM
Hello DrDi,
I looked over your VI, and it should work as you said, even more if you have changed nothing and it stopped to work suddenly.
- First, you should look at your outputs separately : Do they work with NI MAX when you generate a constant signal, or a sinus ? (ao0 and ao1)
- Try the same on LabVIEW, with 2 different tasks in parallel, configured with N samples 1 Channel
- Try each task separately on LabVIEW thanks to the example in the Example Finder
These first steps will inform us about is your module working or not.
