10-25-2018 01:00 AM
Hi!
I am using PXle-6358 daq.
This daq is installed in PXle-1073 and two SCB-68A are used for simultaneous multi-channel measurement.
I try to collect data by receiving a trigger signal on this daq.
I am using the DAQ-USB-6251, which is used by connecting the trigger input signal to APFI 0 (pin 29) and the GND signal to AI GND (pin 30).
I wonder which pin on the SCB-68A should connect the PXle-6358 daq trigger input signal and where to connect the GND signal.
10-25-2018 03:30 AM
As first step, read following link. I think "Direct Feedthrough Mode" is the best setting for you.
SCB-68 and SCB-68A : DAQ Multifunction I/O Accessory Guide
"All 68 signals from the device break out directly to the screw terminals."
As a result, pin29 on PXIe-6358 is connected to pin29 on SCB68A.
