05-24-2006 02:20 PM
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
I reinstalled ms 8.0 and ni driver, framework 1.1, 1.1 server package and framework 2.0 as well. It still doesn't work properly. Anybody knows how to fix this problem. Thank you very much!
05-25-2006 12:51 PM
YHong,
What version of DAQmx do you have installed? You can check this by:
Open the Control Panel05-25-2006 01:03 PM
05-26-2006 09:44 AM
YHong,
Ok, you should try installing DAQmx 8.1 from the website. Here is a link to it. Let us know if that helps, of if you experience the same problem. -GDE05-26-2006 09:55 AM
hi,
Thank you for your help! However, I still feel some strange because I installed the NI-DAQmx 8.0 before, and it worked properly, since I reinstalled my xp, I don't know what happened in my operating system. it didn't work properly now. Anyway, I will try 8.1, but I have one omre question. Before i install 8.1, I need to uninstall 8.0? thank you very much!
05-26-2006 10:21 AM
YHong,
Normally you wouldn't have to, but considering that strange error that you are
getting, I would recommend uninstalling the drivers first, before installing
DAQmx 8.1. It definitely won’t hurt in any case.
