05-29-2006 11:47 PM
06-06-2006 12:31 AM
Hello
Thanks for contacting National Instruments.Its saha.
I have searched about the error you have pointed.I guess your NI-DAQmxBase Driver version is 1.4 or earlier with which this is a common issue.If this is the case, I would suggest you to upgrade your driver to version 1.5 or later which is available from the following site.
Multifunction DAQ:
If your problem is not solved, let me know.
Best of luck
saha | Application Engineer | National Instruments,Japan
06-08-2006 11:08 PM
