NI usb 6008 voltage generation and acquisition
    hello all,
I am a mech eng student who has never touched Labview before until a few weeks ago. so forgive me if my problem is blalantly obvious.
I am trying to make my usb 6008 produce a square wave through so i can feed it to a simple dc motor and measure the response with the usb6008 through its analog ports. I understand i must use some sort of buffer to copy and reproduce the wave again and again. i could not find any examples of waveform generation for this device. it is all very confusing. Please help!
errors I get using DAQ assistant:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in Waveform Buffer Generation.vi->squarewave gen.vi
Possible reason(s):
Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
Task Name: _unnamedTask
(2,562 Views)
The forum is duplicated here:
http://forums.ni.com/ni/board/message?board.id=231&message.id=4152
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,527 Views)
