I have a SCB-68 HSDIO and a SCB-100 connector block that I am using for a design.
I am trying to figure out the size of the screw terminals on both these boards. I havn't seen anything in either of their user guides/data sheets that describe the size of the screws or openings in the screw terminals.
I ultimately wanted to figure out if I could fit a ring connector into the screw terminals.
Does anyone know if this is possible or where I can find this information for these connector blocks?
Thanks.
