Hello everybody,
i set up my NI PCIe-6323 card on my Windows 10 Enterprise LTSC PC according to the manual shown here (getting-started-with-pci-express-multifunction-i-o).
I got stuck at point 4.5. I am able to measure the white noise, but i can not measure a voltage supplied by a function generator (sine wave, 3 Hz 0-200 mV). Afterward, i tried to use the NI PCIe-6323 as a voltage generator via one of the AOs. But there is no voltage applied at the belonging pins (both tests via Test Panels in NI-DAQmx). I run the self-test for my device in NI-DAQmx(Version 21.5.0f329) and it fine.
Does anyone have an idea how to proceed or what could be tested next?
Thanks a lot!
