06-21-2006 03:11 AM
06-21-2006 08:59 AM
06-22-2006 04:10 AM
06-22-2006 04:17 AM
06-22-2006 11:50 AM
Hi All-
I think it's very likely that the power rail problem Graziano referred to is the issue in this case since I'm assuming you're using a rather old motherboard in your PII system. More information about the actual problem and a way to check for the necessary 3.3V rail is available here. The fact that the card works in a newer P4 machine is consistent with the behavior that is common on older machines where a good card simply won't power up if the necessary power rails aren't available.
Hopefully this helps-
06-23-2006 02:50 AM
06-23-2006 09:12 AM
HI Graziano-
I didn't mean to say that they support ONLY 3.3V power rails. I meant to point out that most M Series and some S Series require the 3.3V rail in addition to 5V and normal 12V rails. The KB I linked previously has more information.
Thanks-
