From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
02-06-2007 05:42 PM
02-08-2007 07:37 PM
Hi Gerard,
As far as the firmware on the 6009 is concerned, the USB-6008, USB-6009, and the USB-6501 ship with installed firmware that allows you to use NI-DAQmx Base. The first time one of these devices is plugged into a Windows machine with NI-DAQmx 7.5 or later installed, the NI-DAQmx driver automatically installs the firmware necessary to use NI-DAQmx, which disables the NI-DAQmx Base firmware.
Here is a Knowledge Base Article that talks more about the firmware.
Firmware on USB-6008/6009/6501
Also, could you please elaborate on "but when I start NI-MAX it crashes ". Does it throw some kind of error and then crash or does it just shutdown. One thing you can try is to actually uninstall the driver from Windows Device Manager by right clicking on it and uninstalling it and then plugging the device in again and letting Windows detect the device and install the drivers for it.
The latest version of MAX is just installed with the DAQmx driver that you downloaded, which means that if you downloaded the latest version of the DAQmx driver and installed it, you probably have the latest version of MAX installed as well.
Raajit | Applications Engineer | National Instruments
02-08-2007 09:13 PM
02-08-2007 10:23 PM
02-09-2007 10:37 AM
Hello Gerard,
This might have occurred because of a corrupt installation of the DAQmx 8.3 driver. What you could do is uninstall NI-MAX and reinstall it, or even uninstall DAQmx 8.3 and reinstall it.
You can uninstall MAX by going to Start >> Settings >> Control Panel >> Add or Remove Programs. From the list of software that comes up, go to National Instruments Software and click on Change. This will bring up a list of all NI software. Select NI Measurement & Automation Explorer and click on Remove. The dialog box that opens will list any software components that depend on MAX. Take note of these because you will have to reinstall them. Click on the Remove All button to uninstall MAX and all dependent software.
After everything has been uninstalled, do a fresh installation, and let us know if you are still having this problem.
Best Regards,
Raajit
02-09-2007 03:06 PM
02-12-2007 01:38 PM
Hello Gerard,
Here is an article that talks about the error that you are facing now. It talks about the different reasons why this error might be occurring. Hopefully once you follow these steps, you will not have any more errors .
Why Do I Get a Measurement & Automation Explorer (MAX) Database Connection Error?
Raajit Lall
02-12-2007 01:56 PM
10-01-2008 03:11 AM
10-01-2008 12:21 PM - edited 10-01-2008 12:22 PM
There is KB that talks about potential reasons mentioned above. FYI you should probably create a new thread for new issues.
Have you tried these things? Are you still getting the error? What version of NI-DAQmx are you using? When did this start? Can you give us more details?
Neil S.
