08-21-2016 04:23 PM
I am in need of a DAQ device that can generate both positive and negative constant current. I will be using it to charge/discharge a capacitor repetitively. The DAQ 9265 seems to provide only positive constant current from 0 to 20 mA. So I can charge my capacitor with it but I cant discharge with it. Is there a DAQ device in the market that can solve my purpose?
08-21-2016 07:59 PM
The 20mA signal is because that is a standard signal for sensors in industrial settings.
For arbitrary current sources, you might want to look at a Source Mearsurement Unit (SMU).
08-22-2016 04:14 AM
If you apply the capacitor , why not a voltage controlled current source?
Current needed?
Ground referenced?
Bandwidth?
I like this idea:
or for very small currents
http://www.linear.com/solutions/1185
08-22-2016 11:04 AM
Hi Henrik,
You are right. I can do with a voltage source like NI-USB 6351. That would produce a time varying current.
But in the literature, they generally charge/discharge supercapacitors at constant current.
So I was wondering if there was any instrument available which can generate, say +10 mA for a custom amount of time and -10 mA for another custom amount of time. There can also be some rest period in between the two.
08-23-2016 01:52 AM - edited 08-23-2016 01:57 AM
IF you tell us what your basic goal is we migth find a simple solution 🙂
A simple curent limiter (say a resistor or more fancy a two pole current 'source' in a diode bridge to make it bipolar) migth be all it needs.
But such circuits have a burden voltage ... so, as more specs you tell, as better we can help 😄
08-25-2016 04:08 PM
As Henrik says, the first step is to specify what you want to do. If you are doing capacitor charge/discharge experiments then you need to look into the voltage that the constant current instrument is able to supply.
V=C/Q
So the voltage across your capacitor will increase as you charge it. As you mention the term "Super Capacitor" I assume that you want to store a large charge. So you need to check that the voltage capability of your constant current instrument meets your requirements as well as the current capability.
