From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
NI 9265 has external power of 24 volts but the output channels only read 7 volts
I have a cRIO 9076 with two NI 9265 modules, one NI 9207 module, and one NI 9482 module. The issue I am having is with the NI 9265 modules. I am using an external power supply to provide 24 volts to the module but each of the output channels reads either 7 volts or 13.2 volts. I need the modules to measure 24 volts for each channel in order for the system to function properly. Does anyone know what is wrong or what I need to change to fix this problem? Thanks for your help.
(4,418 Views)
The 9265 is a current output (0-20ma) device. Why are you using this if you need to source a voltage?
(4,414 Views)
What load are you connecting to?  Do you have a schematic of your setup?  The 9265 does have a compliance voltage of 12V, so you shouldn't get much above that.
GCentral
(4,411 Views)
