Multifunction DAQ
NI 9264 Read Setpoint in C#
Is there a way to read the output setpoint from each channel of NI 9264? When I first load the C# application, I would like to read the voltages that are currently being generated out of the NI 9264. I tried using the AnalogSingleChannelReader class, but that doesn't seem to work since these are all analog output channels, and not input.
(932 Views)
Nope, you cannot readback the actual voltage. When you init a DAQmx task, nothing is being generated. You can assume it is at 0V.
Why do you think it is actually generating something?
Please refer to https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/mxcncpts/taskstatemodel.html
Santhosh
Soliton Technologies
(904 Views)
Running the example program "Generate Voltage Update" from National Instruments, I can set the voltage output of Analog output 0 ("ao0") to 4V and verify that it generates 4V. If I then restart the program, ao0 is still generating 4V, and not 0V. The same is true for any voltage I program.
The problem is, when I restart the program, the software has no way of knowing what the current setpoint is.
(882 Views)
DAQ Device Continues to Output Voltage or Current After Closing Device Session
How Can I Maintain an Output Voltage After a Task has Stopped on a Dynamic Signal Generator?
Set ExcitationIdleOutputBehavior property to change this behavior.
Control Lead | Intelline Inc
(873 Views)
Interesting, thanks of the information! I prefer having the idle output behavior to continue outputting the existing value as it's currently doing. I was just hoping I could read what that existing value is when I load up a new software instance. Any ideas how?
(844 Views)
Accepted by desman
Unfortunately, the answer is no. You can store the last output value in a file and read it back when you restart.
Reference: Re: Cannot read back the output from an analog output channel
(826 Views)
