06-20-2006 06:29 AM
06-22-2006 02:18 AM
Officially National Instruments does not support Delphi as a development enviroment. But maybe I can help you a little bit on this control. You should be able to use the following syntax for the channel string either in the properties dialog window of this control or in the function itself:
Hope this helps.
RikP
06-22-2006 07:49 AM
