annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
LabView 7.1 with 64 bit computer
Risolto!
Vai alla soluzione
Does anyone know if there are device drivers that are compatible with LabView 7.1 on a 64-bit computer? And, more specifically, has anyone been able to drive the USB 6009 using LabView 7.1 on a 64 bit platform?
Thanks.
Messaggio 1 di 6
6.327Visualizzazioni
LabVIEW 7.1 support was dropped in DAQmx 8.9.5; thus DAQmx 8.9 is the last version to support LabVIEW 7.1.
What operating system are you using? DAQmx 8.9 supports Windows Vista 64-bit, but no other 64-bit platforms. (Windows 7 was not officially supported until 9.0.2, and we've never supported XP 64-bit.)
Messaggio 2 di 6
6.321Visualizzazioni
Hi protoTest,
LabVIEW 7.1 is officially not compatible on a 64-bit computer.
LabVIEW 8.2.1 is the latest version that can be used on a 64-bit computer.
I hope this helps.
Kind Regards
Michael
NIUK Application Engineer
Messaggio 3 di 6
6.320Visualizzazioni
Thanks for your response.
I'm using Windows 7.
I was able to operate USB 6009 using LabView 7.1 and DAQmx 8.1 on Windows XP 32 bit. This was not a widely known solution, but it worked quite well.
Now I'm wondering if a similar work-around is available for Windows XP 64 bit?
Messaggio 4 di 6
6.315Visualizzazioni
Oops -
I meant to say that I'm looking for a work-around for Windows 7 (not XP) 64 bit .
Messaggio 5 di 6
6.314Visualizzazioni
Soluzione
Accettato da autore argomento protoTest
Hi prototest,
Unfortunately there is no official support in Windows 7 for LabVIEW 7.1. Please consult the following KnowledgeBase article.
Rohan B
Messaggio 6 di 6
6.272Visualizzazioni
