08-24-2017 07:18 AM
Hey,
is the PCIe6321 card the express version of the PCI6221 card?
thx
Koen.
08-24-2017 09:46 AM
Not exactly, but it's very likely a more than adequate drop-in replacement.
The 63xx series boards are the newer X-series design with some improved specs and several significant improved capabilities. I can think of only 1 relatively obscure behavior that I consider *worse* under X-series.
Double-check the specs and pinouts, but you're very likely to be able to substitute seamlessly while gaining some benefits.
-Kevin P
