Is the PCI-4351 card supported by DAQmx?
Is the PCI-4351 Card supported by DAQmx? If so, where do I find the driver? If not, will this happen in the future? I'm aware that I could use traditional NI DAQ, but when I try and load example code such as "NI435X_Getting_Started_Multiple_Transducers.vi" using LabVIEW 8.0, all of the sub VI's, such as "NI435X Acquisition Start.vi", can't be found. Any Ideas?
Mike
(2,629 Views)
Hi Mike,
Your device is only supported by Traditional NI-DAQ (see this page: Data Acquisition (DAQ) Installation/Configuration Troubleshooter).  To use Traditional NI-DAQ with LabVIEW 8.0, you will need version 7.4.1, which you can download here.
-Alan A.
Message Edited by Alan [DE] on 03-15-2006 10:38 AM
(2,622 Views)
