Multifunction DAQ
Is it possible to enumerate devices by AI/AO properties ?
I asked this in the CVI forum yesterday, but there's probably more people who know NIDAQmx here.
Rationale: I'd like to program my app to use whatever AI and AO it can find on a CompactDAQ chassis. It's the 4th upgrade of this app in 20 years and I'd like to leave the possibility to change the hardware without having to recompile.
So I saw AQmxGetSystemInfoAttribute (DAQmx_Sys_DevNames) which gives me a list of connected NI devices.
Great, I can parse that.
But then I wanted to know which ones are analog input and which are analog output.
I first looked at DAQmxGetChanAttribute (Task, Channel, DAQmx_ChanType, &Type) but you need to have already defined the channels yourself... Useless.
Then I looked at NISysCfgGetResourceIndexedProperty() but I don't see any property that will list the available channels and tell me if it's AI or AO.
How is that possible ? Am I overlooking some obvious function call ?
(4,660 Views)
Dunno what kinds of function calls are needed from CVI, but in LabVIEW there's a thing called a "DAQmx Device Property Node" which has a series of cascading menus from which to query dozens of different kinds of device properties and characteristics.
In case you have access to LabVIEW 2013 or newer, here's a snippet.  (Drag and drop the png file onto a LabVIEW block diagram and voila!  it recreates the code.)   There's a lot built into this one node and I suspect it'd take a whole family of function calls in CVI to replicate it.
-Kevin P
 undefined
(4,653 Views)
The same properties are available with cvi but your question is backwards. You don't query a channel to see if it is input or output. You query for devices and then get the number of analog input channels or analog output channels of each device.
(4,640 Views)
Fine... but how do you do that ? I can't find a function to do this, and I just looked at the entire DAQmx tree of function calls.
(4,634 Views)
I don't have cvi at this time but the properties should be very similar to what is shown in the above image. From the property that you've already found, don't you get s list of devices? Don't you see multiple properties listed under device?
(4,631 Views)
Accepted by gdargaud
Thanks, I finally found it by looking at the header file as those functions are not all in the function panel:
DAQmxGetSystemInfoAttribute (DAQmx_Sys_DevNames,    Str, 255);
cDAQ9184-19E4514, cDAQ9184-19E4514Mod1, cDAQ9184-19E4514Mod2
To get the list of devices. And then for each device:
DAQmxGetDevAOPhysicalChans(Channel, Str, 255);
cDAQ9184-19E4514Mod1/ao0, cDAQ9184-19E4514Mod1/ao1, cDAQ9184-19E4514Mod1/ao2, cDAQ9184-19E4514Mod1/ao3
DAQmxGetDevAIPhysicalChans(Channel, Str, 255);
cDAQ9184-19E4514Mod2/ai0, cDAQ9184-19E4514Mod2/ai1, cDAQ9184-19E4514Mod2/ai2, cDAQ9184-19E4514Mod2/ai3
(4,600 Views)
